I have a '99 P38 RR and my brake system suddenly started acting up yesterday with the following symptoms:
When I started the truck up and puched the brake pedal it had almost no proessure and the light turned on. After letting it sit for awhile, it built up pressure. If I drive it, the light turns on when I hit the pedal, but they system has pressure and the light turns off after a second and the brakes maintain adequate pressure.
The pump turns on every 40 seconds for about 1 second the entire time the truck is running.
I need to figure out what is wrong and taking it to a dealer is not an option where I am currently living.
Thanks,
Jeremy
eisenbrj@msoe.edu
Thanks,
Jeremy
eisenbrj@msoe.edu
