I am a new P38 owner (at least its new to me)
, the previous owner gave me 2 keys/remotes 1 recently just stopped working I change the batery's but the ligh wont come on when depressed and the other isnt programmed to the vehicle. Does anyone know how to program a remote?
Also the check engine light is on I have had the codes read and did some research on them they are
P0116
Engine Coolant Temperature Sensor Falling Temp Fault
P0125
Engine Coolant Temp Sensor Warm Up Fault
and
P0118
Engine Coolant Temperature Sensor High Out of Range Fault
assumably there is an engine coolant issue, I dont know how to reset the light on this vehicle to confirm that there is an issue can I get a little direction from you fine people?!?!?
Thanks....
rqchildress@bellsouth.net
, the previous owner gave me 2 keys/remotes 1 recently just stopped working I change the batery's but the ligh wont come on when depressed and the other isnt programmed to the vehicle. Does anyone know how to program a remote?Also the check engine light is on I have had the codes read and did some research on them they are
P0116
P0125
and
P0118
Thanks....
Unfortunately...........
with Testbook or the newer Diag computer. They have you by the ball$ on this one. May be ask RN or Atlantic British if the Autologic system they sell will do it???? There are several Indie Rover shops now that have this system, but I am not familiar with it.
