The cruise control on my 1996 Range Rover SE. is not working. The light on the dash lights when switch is engaged. I have replaced the vacuum tubes engine side of the firewall. I have removed the vaccuum pump and bench ran it, it seems to work.
I suspect the steering wheel switch, the set switch does not spring back as the reset switch does. Is this a possible problem? How difficult is it to get at the switch?
