Having a significant issue with my wife's HSE, "hunting," around the road.
Alignment done twice(and will soon recheck), steering box and drag link replaced. Air suspension converted to coil(fronts were loosing air).
The replacement of the air suspension with coils has helped, but not eliminated the problem.
No clunks from the front end. No shimmy, no steering wheel vibration or pulsation.
Tires are new, but have already seen some uneven wear.
Any thoughts/suggestion are appreciated.
I'm thinking about replacing the steering damper next and possible replacing the drag link bushings.
I thought about a possible wheel bearing as a culprit, but cannot elicit any play in the wheel when it's up on the lift.
Truck has been to the dealer twice without resolution or improvement.
Thanks, John
Thanks, John
