Anyone ever had this problem? When you tap the brake peddle you get this delay. Fells like nothings happening. Let off and press again and it brakes fine. The longer you drive it starts getting sticky and grabbing. Probably the master cylinder. Are rebuild kit's availabe, are these thing hard to bleed if I replace it. Any ideas? By the way it is a 95 4.0 SE.
Brake Problem
