Hi it’s me again, 95 4.0 SE. In the recent cold weather the temp gauge was only going up to just above the cold mark and no heat from the heaters so I replaced the thermostat. Filled the coolant via the header tank and bleed the system according to the rave cd,. Just says to blow back through the air bleed hose atop the radiator back into the header tank. Now the gauge goes up to just over half way and the heaters blow warm but then the gauge will fluctuate between just under the red then back to just above half way. With the engine running the top hose doesn’t feel over hot but is a bit squishy like there is not much coolant there. seems like a air lock or maybe the new thermostat is bad. I do not feel I got as much coolant back in as to the amount that came out.
Could someone tell me the correct procedure to fill and bleed the system.
