I just bought a 1996 range rover. It has a series of issues I need to sort out, but I got it cheap. The message center on the dash tells me the right front door is open all the time, my eyes tell me different. I can't find a switch on the door. Any Ideas? I understand the air suspension won't work if a door is open, so if I can fix the door problem, other problems may be solved.
					Door Open Sensor
 The switch is in the door latch. So, looks like you will need to replace the latch.Kevin
 04 XJ8
 92 RRC
 02 Benz E320
 95 RRC (sold 5/10)
 72 Series 3 (sold 4/10)
 70 Series 2A (sold 6/10)
 Morgan +8 (sold 8/09)
 90 Jetta (308k miles) (sold 5/11)
 72 Triumph Stag (sold 1/08
 I disconnected the wires from the latch, and removed it from the door. I sprayed it with electrical contact cleaner and re-installed it. The "door open" message went away for one day, then came back. I guess I'll head to the junk yard for a new latch.Comment
