1967 Landrover Series II; 88” wheelbase, Safari top, 54,500 original miles; Landrover Limestone original and restored color. $10,000
Pictures available upon request. Just send me your email address. Rover is in Hastings, MN.
I have driven the vehicle about 100 miles since rebuild. Engine runs very smooth, 60 psi oil pressure.
Rebuilt Items: (All parts from Rovers North)
Chassis
§ New Galvanized Chassis
§ New left front fender
§ Rebuilt firewall, new footwells (replaced all rusted sheet metal)
§ New fuel tank
§ Body completely disassembled, painted, and reassembled
§ New rubber seals between roof and body
§ New weather stripping around all doors
§ New sliding window seals driver, passenger, sliding rear compartment windows
§ New Safari roof spacers
§ New galvanized splash guards
§ New galvanized front bumper
Engine
§ Rebuilt Rovers North engine (British Military overhaul with dyno test)
§ New engine mounts
§ New Clutch
§ Rebuilt slave cylindermaster cylinder
§ Electrical converted from generator to alternator, positive ground to negative ground
§ New voltage regulator
§ New coil
§ Radiator boiled and cleaned
§ New radiator hoses
§ New fan belt
Exhaust
§ Complete new exhaust system: pipe, muffler, hangers
Suspension
§ New leaf spring assemblies (4)
§ New shocks
§ New check straps
Brakes
§ New brake shoes all 4 wheels and emergency brake
§ New brake cylinders all 4 wheels
§ New brake lines (complete)
§ Rebuilt master cylinder
Interior
§ New upholstery all seats and seat backs
Electrical
§ New wiring harness
§ All lights are in working condition except turn signals (needs flasher or work on turn signal itsel)
Drive Train
§ New wheel seals (all 4 wheels)
§ New wheel bearings all 4 wheels
§ New output shaft seals, both differentials
§ Rebuilt knuckle joints in both front wheels
§ All gear oil replaced with AMSOIL synthetic gear oil
§ Warn hubs
§ New u-joints
§ New transmission mounts
§ New boots on: drive shaft, transmission shifters, clutch shaft
Things To do:
Ø Vehicle is equipped with stock 15 inch wheels and tires (might be original tires). 16 inch wheels and tires would be better.
Ø Need to finish interior upholstery; roof liner and door liners
Ø Need to install heater hoses from engine block to heater
Ø Need to install defroster hoses from heater to windows
Ø Need to work on windshield wiper motors
Ø Need to work on turn signal switch
Chassis
§ New fuel tank
Engine
§ New engine mounts
§ New Clutch
§ New coil
§ New fan belt
Exhaust
Suspension
§ New shocks
§ New check straps
Brakes
Interior
Electrical
Drive Train
§ Warn hubs
§ New u-joints
Things To do:
