SPECTACULAR, rare Late IIa
  • charles1943
    • Jan 2021
    • 159
    1971 Land-Rover Long DeLuxe Safari Station Wagon.12-passenger model. 14,000 documented miles since new. Quite possibly the most exceptional 109 available anywhere today. Extensively accessorized with recently-fitted equipment, all professionally installed by the winner of 60 international restoration prizes.
    1. Dual anti-sway bars, front and rear
    2. 3/4 –ton/1–ton chassis with raised military spring shackles, fitted to 1-ton positions, giving a taller stance
    3. SALISBURY extreme-duty military rear axle with approximately 5,000 miles since new
    4. New rear propeller shaft for line item 3, above
    5. All recently-fitted master and slave cylinders, both brake and clutch, Genuine Land-Rover or Girling Original Equipment
    6. New old stock SMTIHS dual core heater, with twin speed heater/defroster option, fitted new at restoration
    8. Genuine Land-Rover removeable door tops on all side doors, fitted new at restoration
    10. Vehicle anti-theft satellite location system, similar to LOJACK but not identical
    13. Aircraft cockpit reading/map lights, (with spot/flood, white /infrared options), right and left, over driver and passenger’s outboard shoulders
    14. New three-point inertial safety harnesses, driver and passenger’s front positions
    15. Electrically heated front windscreens, pair, new in 2012
    17. Genuine Land-Rover raised snorkel, bespoke, a period-correct item, not a modern knockoff, fitted by Dare Britannia in 2012
    18. New original equipment muffler and tailpipe, 2014
    19. Complete exterior respray April 2015
    20. Intensive service of steering system in, 2103
    21. Documented updates, repairs, ongoing service and corrective actions undertaken per prior owner’s direction, totaling approximately $13,500.00
    22. Reversing lamps, pair of, period correct, with dual switches (including gearbox-activation)
    23. High-intensity PIAA, driving lamps, complete system, recently fitted
    24. GOODYEAR WRANGLER P235.85R16 tires, set of 5, as new, mounted and balanced on 5 freshly-painted Genuine Rover road wheels
    25. Dual 12-volt dash-mounted 12-volt marine power outlets for accessories and/or charging batteries
    26. Genuine Land-Rover twin military fuel tanks, each with separate fuel transmitters, individually readable at the instrument panel
    28 Genuine Land-Rover Speedometer with trip reset, a rare appointment
    29. Military cluster gauge with engine oil temperature, fuel level (measureable at either tank) and engine water temperature
    30. New overdrive, professionally installed by Dare Britannia, Ltd., circa 2012
    31. Heavy duty, reinforced military front axle, with 24-spline Heavy duty military half shafts
    32. New SUPERWINCH Freewheeling hubs, pair, front, newly-fitted in 2012
    33. Dual-sliding Genuine Land-Rover windows in rear-side doors, uncharacteristic of standard-specification 109 Safari Wagons, fitted new at restoration
    34. Removeable door tops in rear-side doors, uncharacteristic of standard-specification 109 Safari Wagons, fitted new at restoration
    35. Rear military bumperettes, Genuine Land-Rover
    36. New original equipment radiator, fitted 2012
    37. New voltage regulator and rebuilt generator, fitted 2012
    38. Genuine Land-Rover factory-fitted bug screen kit, front cabin
    39. All new Genuine Land-Rover headliners, when restored (approximately 2008)
    40. All new Genuine Rover interior door trim panels and arm rests, fitted new at restoration
    41. New Genuine Land-Rover rear body tub, fitted new at restoration
    42. Three New Genuine Rover rear doors, fitted new at restoration
    43. All factory door locks keyed alike
    44. All new seats, when restored, fitted new at restoration
    45. All new safety harnesses, three-point, BRITAX original equipment, fitted approximately 2012
    46. New HANDYMAN/HI-LIFT 7,000-pound bumper jack, with special under-seat bespoke lockable mount, 2013, as-new condition
    47. Military-specification tropical/extreme-duty oil cooler with tropical 8-bladed military fan and twin-belt drive system
    48. Bespoke thermalacoustic insulation in doors, under seatbox and underbonnet assures quieter operation and cooler summer and warmer winter operation,
    49. Genuine Land-Rover centre under-seat tool tray, military type, with correct locker lid
    50. All new window channel circa 2010
    51 New Genuine Land-Rover B/C side pillar and sill assemblies, fitted new at restoration
    52. Fresh DeLuxe bonnet with spare tyre dish, 2012
    53. Genuine Land-Rover retractable passenger entry steps at all 5 doors, fitted new at restoration
    54. New HELLA H4 quartz-halogen headlamps, pair
    55. Military swivel ball gaiters, pair, on front axle
    56. Rear UK license number plate with bespoke bracket
    57. Rear, aluminum alloy UK country badge with raised letters
    [FONT=Times New Roman][B][I][FONT=Baskerville Old Face][COLOR=#222222]58. Twin cloisonn
