I am working on a 72 series III 88" that has pretty typical rust. I have removed the rear leaf springs but on the rear mount / rear spring / drivers side, the bushing was disintegrated and so the inner sleeve of the bushing came out solidly attached to the nut that goes between the shackles and through the bushing with most of the rubber attached.
The problem is that the bushing's outer sleeve is absolutely snug in the round collet (right word) that is integrated into the frame. I have tried tapping it out but it did not budge. I worked a punch between the sleeve of the bushing and the collet and managed to bend it a bit but it is slow and sloppy going and I am worried that I am marring the inside of the collet and will have difficulty getting the new bushing in (if I get that far!)
Anyone here recognize this dilemma and have the obvious solution for me?
Thanks a lot
Jack
