Results 1 to 6 of 6
Thread: Pitman arm spline question
Hybrid View
    Riverport NS
    33
    Default Pitman arm spline question
    Hello, member for years, very few posts.
    Not strictly a series question but I have installed the Scout II aginaw power steering in my SII 109 and have it on good authority that the Dicovery I pitman arm has the same spline.
    It seems to fit but I'd love to be sure.
    Anyone know?
    Here I am mucking about with it.
    http://www.youtube.com/watch?v=R-M2cH3dzD0
    You'll want to jump ahead to about 4:36 to get to the relevant part.
    I've also asked on Pirate, so I apologise if this is considered a cross post.
    Cheers
    Peter
    Jacksonville, FL and Maine
    1,743
    Quote Originally Posted by PeterK View Post
    Anyone know?
    Cheers
    Peter
    FWIW it doesn't make me cross at all!
    1969 109 P-UP
    Jun 2009
    Columbus, Ohio, USA
    740
    http://www.expeditionlandrover.info/PowerSteering.htm
    Pitman arm - According to Jeff Bigs, a Discovery I pitman arm will work on the Scout II power steering pump. The splines are the same as the Scout box (less the 3,6,9,12 keying), is the appropriate length, and is already tapered for a Rover tie rod end. Alternatively, you can cut the pitman arm that comes with the Scout steering box down to the correct length and thickness then drill and ream it to fit a series Rover tie rod end. The distance between the hole centres should be no longer than 8-1/2 inches. 7-1/2 inches measured centre hole to centre hole works well.
    I feel like it's rare that TeriAnn is wrong.
    Riverport NS
    33
    Thanks Tony,
    I'd seen that, and yes, TAW is well informed.
    I guess I just wanted some first person experience, which I've found and it's all good.
    Cheers
    Phoenix AZ
    1,358
    They will fit but some can be tight. Don't crank down on te securing nut until you know it will go all the way home as it is a pig to get back off for a little fettling.
    Riverport NS
    33
    Quote Originally Posted by greenmeanie View Post
    Precisely my concern.
    Cheers
