Results 1 to 4 of 4
Thread: P0455 ...gross leak / no flow... need help
    Jul 2012
    Pharr, Texas, USA
    15
    Default P0455 ...gross leak / no flow... need help
    Hi to all....
    Well, here I am again asking for help to troubleshoot this code.... p0455... I read that is related to the evap system... but don't know where to start checking....
    any idea or any guess that what is the problem..? or where can I start checking?
    I have erased the code and appears again after 2 or less days... so it has to be something that is bad or in bad shape...
    thanks for all your comments and help....regards...
    Discovery II 2001
    Rebuild > front and rear propshaft, alternator
    Replace > oil pump, water pump, time kit, shocks, engine and trans mounts, front wheel hubs, abs front sensor, trans oil temp sensor, evap valve, trans filter, engine sump gasket, clock light bulb...
    Cleaning > Throtle body, pvc valve..
    Have a nice day...
    Feb 2010
    151
    Jul 2012
    Pharr, Texas, USA
    15
    ok,,, i read it and checking.... posting results later....
    thanks...
    Discovery II 2001
    Have a nice day...
    Jul 2012
    Pharr, Texas, USA
    15
    hi to all... just to end this thread... I finally replace the purge valve and the problems go away.....
    thanks for your help....
    Discovery II 2001
    Have a nice day...
