During the cold winter months I use a winter front that's sheet aluminum covered in black arctic vinyl but it can be opened. One night coming home from work at 4 am the temp had risen and I didn't want to stop on the main hi way in the middle of the night so I kept going. Huge mistake.. I partially seized the engine. I had to install new "standard" pistons and rings but luckily the cylinder walls were not marked so I just glaze busted them. $300 and I was done. For a couple of years I struggled with the engine over heating I tried everything to find the problem then one night on my way to work the temp was ok and as the sun started to go down I turned on the lights and the temp started to rise. Light bulb went on and although I had previously tried an new voltage stabilizer and temp sender and speedo head for the gauge it was a poor body ground. A new ground lead from the body direct to the negative terminal of the battery cured the problem. Sometimes things are not what they appear to be.
