No spark - bypassing the ignition switch?
I replaced the ignition coil on my iia because I thought it was the cause of a no spark condition. I still don't get any spark doing the test from the ignition coil main cable to the block. starter motor cranks just fine.
My thought is there is something wrong in the LT circuit and I want to bypass the ignition switch to eliminate it from consideration.
Any other ideas would be grand!
Thanks for reading.
