Results 1 to 7 of 7
Thread: Where to mount seatbelt
    Aug 2016
    Plant City, Florida
    58
    Default Where to mount seatbelt
    Where should the inertia reel (retractable seat belts) be mounted on a Series. I only see the back of the seat box as an option. There is not enough clearance on the door post. I bought HMMHV 3-point belts.
    Mine's mounted to a bracket behind the door opening, onto the galvanized trim. See photo:
    Aug 2016
    Plant City, Florida
    58
ID:	12100Click image for larger version.
ID:	12099Click image for larger version.
ID:	12098Click image for larger version.
ID:	12097Here is how I did mine
    Hey, Armordave,
    How did you remove that bolt that holds the seat belt to the seat frame? There's no room to fit a socket.
    Deleted
    ArmorDave,
    How do you loosen that large bolt that the original seat belt is fastened with to the seat box? Because the door jamb is so close (not to mention that bolts holding the triangular bracket to the body), I can't get a socket or even an open-ended wrench on it.
    Thanks,
    Phreaddy
    Dec 2010
    77
    armor dave: true, it's a tight fit, sorry but I don't recall how I got mine off, maybe i took the whole bracket out?
