Replacing Seals: Anyone in Eastern, NC?
So the rover needs to have a few items replaced....seals where the drive shaft goes into the front and rear pumpkin, and ebrake drum seal ...can't remember the technical term.
I just do not have the equipment to do the work right now and looking for someone in the general area that could do the job or work with me. Willing to drive a few hours if need be.
I just replaced the oil pan gasket and valve cover gasket. Just trying to go through and replace a lot of things since the rover sat out in the weather (in the mountains) for 3 years without being moved before i bought it. So a lot of misc items went bad over the back to back winters/summers.
1971 Series IIa Hybrid: 2.5L MILSPEC 5-Main Bearing Engine|Turner Engineering Performance Head w/ oversized hardened steel valves & phase shift/increased lift cam|LT77 Tranny/LT230 Transfer Case|11mm Ignition Wires/Super Coil|Jacobs Ignition/Petronix Ignitor|D90 Axles|Galvy Frame|Old Man Emu Coils|Cust Rear/Side Fuel Tanks|Cust Drive Shafts|
