Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: New Project Rover – Brakes Repairs & Low Compression
    Feb 2007
    Seattle, WA
    27
    Default New Project Rover – Brakes Repairs & Low Compression
    Hi Folks,
    I'm a new member, although I;ve been reading the posts for several months now. I just purchased my first series rover, a 1971 Series IIa SWB (it’s my 2nd Land Rover, I also have a 2000 Discovery II). I hope to get some pictures posted of the “new” rover soon.
    The first thing I’ve done so far was a brake inspection and a compression test.
    Brakes: the brakes need a complete overhall. New shoes, cylinders, rubber lines. The drums are smooth inside but look pretty old on the outside (surface rust). Should I leave the drums as is, get them resurfaced, or replace them? What’s the minimum drum thickness? How do I test the vacuum booster? I thought I saw a post on this before but can’t find it now.
    Compression test: cylinders 1, 2, 4 (numbered from front to back) were at 160 psi. cylinder 3 was at 90 psi. I squirted oil into cylinder 3 and retested and it still came back at 90 psi. this indicates a leak at the valves and not pistons, correct? Does this mean that I need a complete valve job? Or is there a way to clean the valve (assuming that carbon buildup is the problem)? should I even be concerned with this, or should I run it as it?
    Also, I just purchased the Haynes Restoration Manual & Haynes Service and Repair Manual. Are there any other useful manuals that I should consider?
    Thanks
    Mar 2006
    twisties~South Lake Tahoe tarmac rallye style
    733
    Welcome to the forum! Yes, photos are always great to see, please post when you get a chance.
    Cheers, Thompson
    Rovers North, Inc.
    Oct 2006
    North MS
    980
    Quote Originally Posted by TSR53
    You could make it easier to post photos, by raising the ,ahem, pathetic 39kb limit.
    67 IIA 109" NADA Wagon (sold)
    Mar 2006
    733
    Request granted . [actually, no one ever asked before...]
    Now it's set to 235.2k max file size, max width 1024 x max height 768.
    TS
    Quote Originally Posted by jp-
    Cheers, Thompson
    Rovers North, Inc.
    Oct 2006
    North MS
    980
    Thanks,
    Thompson
    Oct 2006
    North MS
    980
    Thanks for the link King.
    There's some neat stuff there.
    By the way, where did you get the water injection setup for generator?
    How did you meter the amount of water being injected?
    What was the rate of water to fuel (or oil)?
    Oct 2006
    Hilo, Hawaii or Santa Ana, CA
    177
    thumb-up Valve adjustment and Green Bible...
    I would suggest doing a valve adjustment and tuneup then checking the compression again. If you are holding some compression, it might be the valve is too tight and leaking or some carbon build up. An easy way to clean out carbon assuming the engine runs is remove the everything above the carb, warm up the engine, with a spray bottle and just water bring the engine up to a reasonable running speed, shoot a few squirts of water down the throat of the carb, the engine will lug then pick up again, repeat, I usually do a complete spray bottle. Its engine steam cleaning, be sure the exhaust it pointed in a safe direction so you dont paint your garage with carbon guk.
    I would suggest you get a copy of the Green Bible, much better than any other manual. You can find an online copy: Here
    Do you have a problem with the brakes? I would replace the fluid and adjust them, if the fluid is black/creamy/rusty or you have leaks I would start tackling that problem. Again refer to the GB.
    Visit The Wandering Hippo (my 109 S2A Ambulance).
  8. #8
    Oct 2006
    North MS
    980
    Quote Originally Posted by KingSlug
    I shoot a few squirts of water down the throat of the carb, the engine will lug then pick up again, repeat, I usually do a complete spray bottle.
    I've never heard this before, but it sounds risky.
    King, how do you know it works? Have you done a disassembly after trying this?
    Because I can see some potential for engine damage if you're not careful.
  9. #9
    Oct 2006
    177
    thumb-up
    Its an old mech trick, yes it works. Try googling it. You are only misting water down the carb not dumping a straight gallon. If you have a cooking pan thats all carboned up and you dont want to scrub, place water in it an bring it to a boil, taddah.
    Look down this page:
    http://www.hotrod.com/tipstricks/41918/index5.html
    We used a timed water injection system on a Lister 12/2 CS diesel that ran on used motor oil. The water injection kept every thing inside bright and shiney, if the water ran out the injectors would clog in an hour. The light gen ran 24/7 sometimes all summer, it was started and finished on diesel. There is a big difference between diesel and used motor oil and water made up the difference.
    Here is another cute old engine trick. Your truck idles fine but cuts out at freeway speeds. With the air cleaner off get as much rpm as possible and slap you hand over the carb and let it choke. You are hoping the vacuum will pull any junk/dirt out of the carbs holes and orfices, this will normally return the engine to normal conditions and is sometime cause by crab in the fuel the stock LR filter wont catch but check the fuel filter also.
  10. #10
    Nov 2006
    N. York
    1,635
    It is one of those well established old tricks. Some people used brake fluid, oil of peppermint etc. Think of them as old time home remedies for engines.
    Land Rover UK Forums
