Results 1 to 7 of 7
Thread: Fitting on a spin on oil filter adapter
    Sep 2008
    Chicago Suburb
    106
    Default Fitting on a spin on oil filter adapter
    Ok, I know is it on here but, but cannot find it. Does someone have the directions to install a spin on oil filter adapter. I know many have installed it backwards and I want to make sure I do not this.
    Thanks in advance,
    Brett
    1968 Series IIa 88 w/ hardtop - SOLD
    1970 Series IIa 88 (parts car)
    M416 Trailer
    2008 Toyota FJ
    2009 Volvo C30
    1983 D110
    http://68landy.blogspot.com/2010/01/blog-post.html
    Feb 2007
    Phippsburg, ME
    886
    Quote Originally Posted by usadventureracing View Post
    Thanks in advance,
    Brett
    Which one do you have?
    Sep 2008
    Chicago Suburb
    106
    Looks like the part number is RTC 3184...thanks
    M416 Trailer
    2008 Toyota FJ
    2009 Volvo C30
    1983 D110
    Mar 2007
    New Mexico
    364
    Question
    Sorry but I don't know what style the part # is for. Does it look like this
    Or is it a 1 piece adapter like in this pic?
    The one piece pictured orients the sending unit towards the front of the motor in the proper orientation. My bud scott has this style adapter. His is also stamped with the words "top" and "front" which help orient the unit. Pretty straight forward. On my Series I have the 2 piece style. I think it's referred to as a "pancake" adapter. Proper orientation with mine using a Fram PH8 filter has the sending unit oriented more towards the rear of the motor.
    1991 Range Rover Hunter
    Sep 2008
    Chicago Suburb
    106
    I have the 1 piece...thanks
    M416 Trailer
    2008 Toyota FJ
    2009 Volvo C30
    1983 D110
    Dec 2006
    Southern Maine
    279
    I also a have a 1 piece adaptor I'm considerng using but there are a few things I'd like to undertand.
    1.) why does the oil sender port in the cast OE filter assy have a check ball? or is it more of a surge protector?
    2.) My series III has 2 senders. I assume one is for the low oil pressure light and the other for a gage. (I need t look back at my wiring diagram).. but oddly the car never had an oil pressure gage ??
    ...Talbot
    Jul 2007
    Davenport, IA
    325
    On my 74, the oil light comes from the switch (sensor) on the filter, and the gauge has a separate fitting (just removed it Saturday, and already I can't picture where it is, I'll look tomorrow).
    A white/brown tracer wire should go from the switch on the oil filter (sensor - which is grounded by attachment to the block via the filter/adapter) to the 9-pin connector, then into the main harness, through the firewall, and to the dash warning light.
