Results 1 to 7 of 7
Thread: Lower Dash Parts
    Default Lower Dash Parts
    I have a 1994 RR Classic LWB (hard dash) and am looking for lower dash trim parts to replaced cracked pieces. replacing heater core and fan and thought I would take care of these pieces at same time but have not had success locating the parts on the web. Trim around radio and cig lighter needed. Guessing I need to find someone parting a classic. Any direction would be great.
    Thanks
    Oct 2006
    1,199
    Your search can literally take years. If your parts are just cracked you are better off repairing them. A lower dash goes for around $4-450 in good condition. The LWB ones are even more since they have the switch panels on either side of the radio.
    It is not out of the question to buy a parts truck that is rusted out but has a complete interior. Take what you need and scrap the rest and get 5-600 bucks out of it for scrap value.
    Thank you. Do you think an 89 lower piece will fit. I know the 89 piece does not have locations for buttons but air suspension was removed and heated seats don't work so was thinking I would cap lines and do without if it will fit. Found an 89 piece for under $100
    Oct 2006
    1,199
    The answer is, maybe. My first reaction when I saw the question was no, won't fit. However you may be able to get it to work. There are some differences, and I can't recall whether those differences are enough to make it not fit or whether those differences mean it can be MADE to fit. 91-94 fits for certain. Earlier, dunno.
    May 2006
    2,020
    The fuse box layout is somewhat different and the radio is slightly altered in its location.
    With some gaffer tape I guess it would work....
    Default Need Help Locating Dash Panel
    Hi all...
    I'm trying to locate an extra uncut dash panel to run a voltmeter/USB cluster through.
    I need the black piece that's circled:
    Thanks!
    May 2006
    2,020
    Nice airportable !
    Sorry, cannot help with the dash part, all ours have gauge holes.
