Results 1 to 9 of 9
Thread: Speedo cable keeps breaking
    Default Speedo cable keeps breaking
    I know I’m going to feel really stupid when I get the answer, but after 3 broken Speedo cables in my 70 Series 2a 88, Im ready to ask. Here’s the drill-
    Third Speedo cable just broke at the transmission end. All broke within 2 miles or less after installation.The speedometer is in working order, sent it to Ike at Pangolin just to be sure. I’ve installed at as carefully and kink free as I know how to do after lubing it. Any ideas on what I’m doing wrong?
    Jul 2020
    UK
    307
    Quote Originally Posted by bob7088 View Post
    Check that there is not a piece of broken cable stuck in the drive square , gearbox end . I had this and the cable broke and. damaged the speedometer. The inner cable should slide in and the outer abut the housing with no need to compress to fit
    Have you strictly followed the routing as per LR Manual ?
    Sep 2010
    killingworth CT
    836
    Since we are on Speed om Meters and cables. I occasionally get what seems to be a dis-engagement of my speedometer cable at the gauge resulting in a big annoying noise from the speedo,, I', not sure what is happening, any suggestions anyone? Is my cable retracting and not engaged? Is the Cable buggered, and in need of replacing?,,,,
    Default Issue
    I'd put my money on the speedo being faulty. Either that or the cables are improperly made. And the drawing shown is also incorrect: it's for a Series I. The later cables were meant to lead up over the top of the chassis, unlike the drawing.
Size:  70.7 KB[/QUOTE]
    Jul 2020
    UK
    307
    Quote Originally Posted by charles1943 View Post
    [/QUOTE]
    The drawing is from a LR 2A Workshop manual 606408, although I admit its the 1st edition dated March 1969
    Yes, that’s the same picture that’s in my green bible, too. When you say it goes over the chassis, do you mean between the chassis and the floor?
    Dec 2010
    411
    if you have one not broken, hook it up to xmission but NOT speedo. drive and see what it does, you can also reach into the guage and see if the receptacle in there turns free?
  8. #8
    Have you tried withdrawing the inner cable and greasing it liberally? If not, that could be your noise.
  9. #9
    Dec 2010
    411
    good thing bob, fill that cable with grease!! ........... i don't recall if the end comes off to allow for this but i think it may.
