BAD STARTING 3.0 DIESEL BMW ENGINE
2003 MODEL.has any one come across bad starting from hot or cold, it will start but you must , crank for over a minute, yes is the fuel runing back, change fuel filter and check connections, looks like fuel in plastic line, no bubbles , i think poss weak fuel pump, because if you jump it and the engin spins fast it will start ok, untill you leave it for 4+ hrs, some times its a pig only after 5 mins?
the other pain is the viscoss fan sounds like it a plain, so replace it still the same, then it was ok for a hr, are there flaps or switch that open and close air vents on or off ??
RANGE ROVER 3.0 DIESEL BAD STATING FEELS LIKE FUEL
ANY ONE OUT THERE COME ACROSS THIS
I had this problem for a while. After few weeks it complidly failed to start.
It was a fuel injection nozzel wich had to bee changed.
To find wich, loosen the return pipe from the nozzel - one at a time - turn the starter, and the one wich not give oil is the bad one.
Hope you can use tis.
Ole
RANGE ROVER BAD STARTING
Still have problem , but we have notice that there is no feed to the diesel injectors and this stops the injectors opening and will not start , as soon as you get a slight voltage and out test lamp starts to flash she will burst into life, so lets have a list of sensors or parts that operates this ecu ????
- You may not post replies
- You may not edit your posts
Forum Rules
