![Quote](images/metro/green/misc/quote_icon.png)
Originally Posted by
cousindave
I stuck a thermometer in the radiator after gauge read in the red. I got 145° . Let me add that I'm running without the thermostat. Also, when I oened the raxiator I noticed the antifreeze was foamy. Is that normal? I also noticed the smallest pinhole leak out of the radiator. Could that cause the foaming? Or even the overheat conditions? What temp is overheating in a series III? thanks
Normal operating temp for a 4 cylinder should be between 180F and 200F. Overheating would be 220F+. The thermostat wouldn't even open until the temp reached 72C or 162F (Series III manual thermostat rating).
Foamy antifreeze doesn't seem normal.
IMHO a pinhole leak would keep the cooling system from maintaining the correct pressure of around 9 lbf in^2 (which is the rating of the radiator cap according to the Series III manual)
Walker
1968 Series IIA-"Ronnie"
88" SW, 2.25L Petrol, LHD
