pre inspection check out
thought i'd check my lights before I get the 74 inspected. Due March 31st, little late. Well front right driving light and left reverse lights are out. Reverse light was easy, cleaned connections, good. Front right was more of a PITA, after tracing down the problem to the ground lead on the light I found the ground connector at light was disconnected. Reconnected it with a little solder good to go.
Put the bulkhead cowl, tunnel cover and floors in the 109. Preping for a test drive of the brake upgrade and clutch slave and reservoir work.
THING 1 - 1973 88 SIII - SOLD
THING 5 - 1958 109 PU
THING 6 - 1954 86" HT
