Manual Transmission and ECU
I have a 95 auto disco. The body is off the frame, engine and trans removed, and I'm reconditioning the frame. The idea here is I am trying to do a nice off road build.
I just got a donor 95 disco with a manual trans and a nice low miles used 5-speed from roverland still in the crate. I know that the clutch box, master cyl, radiator, and all that good stuff will be changed over when I rebuild.
However, with regards to the ECU...Do I have to remove the engine ECU (the one near the heater blower) or can the one in the auto body simply be reprogramed? Is there even a trans ECU on a 95?
Also, other then the hardware involved in switching over, are there any other electrical components I should be away of?
Thanks for any help
Dave
"Out of every one hundred men, ten should not even be there, eighty are just targets, nine are the real fighters, and we are lucky to have them for they make the battle. Ah, but the one, one is a warrior, and he will bring the others back"
