I have the fiber glass top Land Rover made, it cracks and is very noisy. Is there a manufacturer who makes an aluminum top similar to the non-removeable tops for the new defenders?
All the D90 tops are removeable...
1995 110 Regular
Even the new ones???? i am looking for an aluminum hard top that i can remove during the summer for my 95 d 90
The question is: how easliy.
They all remove; the ones with the roll bar passing through them are more difficult than those that do not.
If you had a soft top and want to add a hard top, you need to change the roll cage (on NAS models) because of all that ugly padding they put on it. I do not believe you can remove the padding, but maybe you can?
Then you can go topless, or hard top, but the soft top will no longer fit properly.
The 90 is not like the old series trucks, where any roof could be used.
But to answer the question again, any roof CAN be used on any 90; the simple question is how badly do you want to do it, and how much time do you have to change roofs. It won't be a five-minute, one person job that's for sure...
1995 110 Regular
Use this: http://www.d-90.com/mod/sw2st/index.htm Just in reverse.
