94 Disco 1 3.9 Running rough
  • baetis99
    • May 2010
    • 2
    Please help, new to this forum and my Disco 1 recently started not starting as well, but when started it ides fine. As soon as step on the gas and put it in gear it has no power until I get above 3000 rpms and then it runs great. Plugs aren't fouling and wires are new. Oil and coolant look normal and I have no warning lights. Thanks in advance.
    1994 Discovery 3.9
    Vail, Colorado
  • joshua.mcguoirk
    • Sep 2007
    • 122
    Vacuum Hoses
    From what you describe... It sounds to me like a vacuum leak.
    Confirm that all hoses are in good condition. Some forget to include the hoses for the cruise control.
    An old mechanics trick:
    1. Start vehicle.
    2. Open hood.
    3. Using the gas ONLY from a propane torch, run over all vacuum hoses.
    If idle increases... you found the bad hose.
    Otherwise, its something else... like the timing. Easily check with a "timing" light.
    Cheers,
    1990 RRC, 3.9L, AUTO "Willow Pond" (Sold)
    1996 D1, 4.0L, AUTO "Lucas"
    1999 RR, 4.0L, AUTO "Belle" (Sold)
    • baetis99
      • May 2010
      • 2
      Thanks Joshua, I'll give the entire vacuum system a close look. Great tip on using propane to find the leak. If that doesn't work I'll pull out the timing light.
      1994 Discovery 3.9
      Vail, Colorado
