How do I change the temp from C to F? After disconnecting the battery it used celcius as the default.
Reset temperature reading
Resetting temperature
Maybe I wasn't clear with my question, so I'll try again. How do I change the temperature display from celcius to farenheit? There must be some combination of buttons that toggles the display back and forth between the two scales. Does anyone know how to do that? -
You will need to push the "recirculation" button AND the "on/off" button at the same time (for about 3 seconds)Originally posted by 03lrdiscoWith the Climate Control on press and hold the recirclation tab for Three seconds or so... that should work
Peace,
ArtComment
