Reset temperature reading
  • bkarow
    • Aug 2007
    • 17
    How do I change the temp from C to F? After disconnecting the battery it used celcius as the default.
  • bkarow
    • Aug 2007
    • 17
    Resetting temperature
    Maybe I wasn't clear with my question, so I'll try again. How do I change the temperature display from celcius to farenheit? There must be some combination of buttons that toggles the display back and forth between the two scales. Does anyone know how to do that?
    • 03lrdisco
      • Oct 2007
      • 8
      With the Climate Control on press and hold the recirclation tab for Three seconds or so... that should work
      • rover_chump
        RN Veteran
        • Jun 2006
        • 53
        You will need to push the "recirculation" button AND the "on/off" button at the same time (for about 3 seconds)
        Peace,
        Art
        Philippians 4:6
        • bkarow
          • Aug 2007
          • 17
          Peace,
          Art
          Thanks! That worked.
