So I have my S3 running pretty well now and I just replaced the clutch hydraulics. I bled the system as per the LR instructions but it doesn't seem like it's working correctly. (I've never driven this rig since it didn't run when I bought it.)
The trans will go into gear while the engine isn't running but upon starting it will not go into gear. With the clutch pedal in, I can try to engage any gear and it will start turning the tires while not fully going into gear.
I've replaced the clutch master, slave, flex and steel lines. I adjusted the clutch pedal so it has almost as much travel as the adjuster will allow and the clutch pedal is almost even with the brake pedal. I also replaced the clutch return spring.
My other question pertains to my overdrive. I've never had one before and mine is a Toro. The lever has three positions, overdrive engaged, neutral, and overdrive disengaged. Should it be in neutral or disengaged?
I'd appreciate any guidance you could provide.
