hey gang,
Long time no chat. I've been enjoying catching up on the threads this morning.
Graduate school and full time work has pretty much killed my extracurricular activities including driving and maintaining my rover
However, by the looks of the clouds I have about an hour before our first winter storm rolls in. Seems like a good time to takle my starter issue, right?
Over the summer, when I was still driving the rover on the weekends, occasionally when I turned the key, it would just click. Usually the 2nd or 3rd turn would get it going. Now, it only clicks...nothing.
It's a new starter, less than a year old. Some may remember that i have a funky 2.5L engine where just enough is different from the 2.25 to be substantially annoying. The starter is one of those differences. I had to order my from the UK. These starters have the advantage of being a slightly more modern design with an integral solenoid. They have the disadvantage of being too unknown for any of the local rebuilding shops I took my last one to.
I brushed up on other posts about starters (pun marginally intended) and have a few ideas of things to check:
It's the last one that has me a bit worried. What's the procedure there? Is it as simple as putting the truck in neutral and using a suitable wire (jumper cable)? I guess my concern is being under the truck and trying to start it. I'll chock the wheels and put the transmission and transfer case in neutral. Do I want the key on or off? I'm assuming if off, the starter may spin up, but the engine won't start since there's no power to the plugs, etc... is that the best way to test, or do I want the ignition engaged?
Any other tips or thoughts?
edited to add:
Just had a duh moment... make the connection at the battery, not the starter!
- All the wires and ground connection
- battery condition and voltage
- whack it with a hammer (working solo today, can I hit it and then try and start it? Or does it have to be when someone is turning the key?)
- jumping the positive....
edited to add:
