Sewer Cap diff pan ok?
  • BGGB
    • Jul 2008
    • 83
    hey everyone, i in the process of rebuilding my 69 bugeye and the rear diff pan is shot, i ground it off and looked for the pipe end cap. my dad knows a guy who works for a company that lays gas lines and he made this up for free. will this work alright. the original has the grove in it and i assume it is there to help the oil get slung on all the parts. this pan is much larger (also much heavier), do you think i have to worry about anthing. this rover will never be ******** off roader so im not worried about the extra overhang. also im doing this rebuild and im on a budget, i would rather have something more appealing but it was free so i can't complain there
  • bkreutz
    • Apr 2010
    • 408
    Just going to take a bunch more gear oil. But then the gear may run cooler with the increased fluid volume. Anyway, the price is right.
    Gale Breitkreutz
    '03 Disco
    '47 CJ2A
    • LaneRover
      • 1743
      That needs a nice big smiley face on it!
      • 4flattires
        • Aug 2007
        • 424
        I'd paint Starkist on the side and emblazon Charlie the Tuna popping out of the can.
        64 SIIa 109 all stock
        69 SIIa 88 all stock
        Old tractors
        New Harleys
        Old trucks
          I'd probably just paint it red.
          • JSBriggs
            • 111
            It will work. For about $25 you can get an 8" weld on pipe cap (dome shaped cap) that is 1/4" thick, and wont get hung up offroad. That is what I run on most of my trucks.
            -Jeff
            • akedtg
              • Oct 2011
              • 8
              That is huge!!
              I would be concerned about the gear oil when going up a hill running to the back of that cover and not making contact with the ring gear and not slinging oil to the pinion.
              you are right about the shape of a diff cover! they are like that so when you do go up a steep hill or are low on fluid it channels the oil to the pinion via the ring gear and keeps the diff lubed.
              If you live in the flats I say go for it!
              • BGGB
                • Jul 2008
                • 83
                Hey jeff do you have a website or somewhere where you could point me?
                for 25 bucks i think id rather that design.
                I actually live on a hill so i think i might have to change the design a bit, although the cap is much larger than it needs to be i think i could probally shave an inch or more off with a torch after some carefull measuring, this would keep the oil closer to the gears.
                Thanks everyone for your replies, and i had considered a smiley face, not a monkeys *ss though.
                • slorocco
                  • 208
                  You need something like this for 8" pipe. Find a local plumbing supply place and they should be able to get you one.
                  • HybridIIA
                    • 98
                    I don't think you will find a pipe cap for $25, but McMaster has them for $65. Here is a link w/ drawing...
                    McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
                    '62 109 - coil sprung
                    '64 88 - coil sprung
                    • Apis Mellifera
                      • 386
                      Since the original is stamped steel welded on and you'll need to weld a new one on, why couldn't you buy of of thesehttp://www.ebay.com/itm/GMC-Buick-Ch...sories&vxp=mtr
                      remove the flange and weld it on?
                      • slorocco
                        • 208
                        The advantage of the pipe cap is that it's virtually bullet proof. No need for a separate diff guard.
                        • alaskajosh
                          • Sep 2007
                          • 208
                          http://www.mcmaster.com/#cadinlnord/43425k246/=gi3xqb
                          I think I paid $30-$35 for mine at my local plumbing wholesaler.. and that's Alaska pricing.
                          • slorocco
                            • 208
                            I also paid about $30. That was 3 years ago in Maryland.
                            • lrdukdog
                              • 321
                              Diff cap
                              "Sewer Cap diff pan " Looks more like a "Top hat diff cover" to me.
                              Jim Wolf
