hey everyone, i in the process of rebuilding my 69 bugeye and the rear diff pan is shot, i ground it off and looked for the pipe end cap. my dad knows a guy who works for a company that lays gas lines and he made this up for free. will this work alright. the original has the grove in it and i assume it is there to help the oil get slung on all the parts. this pan is much larger (also much heavier), do you think i have to worry about anthing. this rover will never be ******** off roader so im not worried about the extra overhang. also im doing this rebuild and im on a budget, i would rather have something more appealing but it was free so i can't complain there
Sewer Cap diff pan ok?
That needs a nice big smiley face on it!
I'd paint Starkist on the side and emblazon Charlie the Tuna popping out of the can.64 SIIa 109 all stock
69 SIIa 88 all stock
Old tractors
New Harleys
Old trucksComment
That is huge!!
I would be concerned about the gear oil when going up a hill running to the back of that cover and not making contact with the ring gear and not slinging oil to the pinion.
you are right about the shape of a diff cover! they are like that so when you do go up a steep hill or are low on fluid it channels the oil to the pinion via the ring gear and keeps the diff lubed.
If you live in the flats I say go for it!Comment
Hey jeff do you have a website or somewhere where you could point me?
for 25 bucks i think id rather that design.
I actually live on a hill so i think i might have to change the design a bit, although the cap is much larger than it needs to be i think i could probally shave an inch or more off with a torch after some carefull measuring, this would keep the oil closer to the gears.
Thanks everyone for your replies, and i had considered a smiley face, not a monkeys *ss though.Comment
You need something like this for 8" pipe. Find a local plumbing supply place and they should be able to get you one.Comment
'62 109 - coil sprung
'64 88 - coil sprungComment
Since the original is stamped steel welded on and you'll need to weld a new one on, why couldn't you buy of of thesehttp://www.ebay.com/itm/GMC-Buick-Ch...sories&vxp=mtr
remove the flange and weld it on?© 1974 Apis Mellifera. Few rights preserved.Comment
I don't think you will find a pipe cap for $25, but McMaster has them for $65. Here is a link w/ drawing...
http://www.mcmaster.com/#cadinlnord/43425k246/=gi3xqbComment
