New to winching, what line should i get?
  • masonater
    • Nov 2007
    • 329
    #16
    wow, great info here. Thanks for the responses. Now i know what to research. I like the idea of tight weave wraps that block sand. It was gusting 40 today, sand went everywhere. Safety thimble is very slick, will get that for sure. Ive been looking at the winch plows, very cool tool. Already have some good gloves and recovery strap. i need some good USA shackles and a tree strap, even though all we have are dead pine trees and scrub oak bushes.
    1970 Series IIA 109 EX-MOD
    1971 Series IIA 109 EX-MOD
    1982 Mercedes 300TD
    1989 RRC
    1993 D110
    1994 RRC LWB
    1995 RRC LWB
    1995 RRC LWB
    1995 Disco
    1996 GMC 2500 Suburban
    1996 Disco
    1997 Disco
    2001 RR P38
    2005 LR3 HSE
    2006 RR HSE
    • antichrist
      • Mar 2009
      • 272
      #17
      I like CM shackles.
      Columbus McKinnon's portfolio of trusted worldwide brands can help you safely and efficiently move your materials, and business, forward.
      I use the ones with a 5:1 design factor because it let's me go slightly smaller yet still have a good safety margin. Keep in mind that the "ultimate strength" is when it begins to deform, not when it breaks.
      Here's a video of what I mean. http://www.youtube.com/watch?v=513Rn7uuJao
      I don't know the brand, but it gives you an idea.
      The Van Beest green pin are another good brand of shackle.
      I have several of their self-locking eye hooks and like them. They do need to be sprayed with WD-40, or the like, periodically.
      Tom Rowe
      62 88 reg
      67 NADA x2
      95 D1 - R380
      95 D90 - R380
      97 D1 - ZF
      • yorker
        • 1635
        #18
        I usually hunt down Crosby shackles. http://www.thecrosbygroup.com/ I've always had good luck with them.
        Crosby carbon shackles have the highest design factor (6 to 1) in the industry. All of Crosby’s design factors are documented. Crosby purchases only special bar forging quality steel with special cleanliness and guaranteed hardenability. All material chemistry is independently verified prior to manufacturing. The design of Crosby shackles assure that strength, ductility and fatigue properties are met.
        Land Rover UK Forums
        • LR Max
          • Feb 2010
          • 315
          #19
          Sounds like finding a point to tie off to might be difficult. I see you are in Nantucket. While I am not familiar with this place (I take that back, I got kicked out of the hat shop there when I was 17) but it sounds like trees might be few and far between.
          A ground anchor might also need to be included in your setup. A winch isn't any good without something to attach it to!
          Of course the pul pal is great. But if you are handy, I've seen a number of ground anchors made out of an old semi-float axle shaft. Grind the spline side down to a point (or if you find a broken one, then it might already have the point on it ), weld a simple "plow" about 8" from the wheel flange, and you are good to go. Hammer it into the ground and start pulling. If you weld a big enough plow to it, it might perform alright in the sand. Hammer it in, then use hi-lift to get it out. Cheap and semi-easy considering you MIGHT use it once a year.
          Do a little looking around. Like I said, cheap and actually fairly compact.
          Dunno, just a suggestion. Normally I never think ground anchors are worth their weight in a rig but for sand, it is a whole other ball game!
          • yorker
            • 1635
            #20
            one of those would be worth looking into.
            or:
            http://www.freepatentsonline.com/6564515.html
            • bpj911
              • May 2009
              • 128
              #21
              this is what we use
              They come bigger and longer as well. We use them at work all the time
              • antichrist
                • Mar 2009
                • 272
                #22
                Oops, thanks, forgot about them.
                Tom Rowe
                62 88 reg
                67 NADA x2
                95 D1 - R380
                95 D90 - R380
                97 D1 - ZF
                • yorker
                  • 1635
                  #23
                  I just like Crosby shackles- but honestly have no specific reason to chose them over the other good brands. The 45 degree marks ont hem are kind of cool. I also try to buy other rigging bits made by Gunnebo:
                  As long as you insist on a reputable brand you'll be ok. The Chinese ones might be ok too but I just won't take chances on stuff like this. I imagine most people feel the same way.
                  Masonator: don't forget a couple snatch blocks:
                    #24
                    Hmm. Winches? Shackles? Ground anchors? Snatch blocks?
                    Perhaps Nantucket is a little more of a remote, rugged, inhospitable operating environment than everyone thinks when they picture Nantucket? Kinda sounds like a 4x4 off-road enthusiast's heaven.
                    Martha's Vineyard is probably the tame, laid-back place I'm thinking of...
                    • I Leak Oil
                      • 1796
                      #25
                      Ouch!
                      Which island has Jaws? Perhaps the winch could be used for a little heavy duty surf casting?
                      • masonater
                        • Nov 2007
                        • 329
                        #26
                        Jaws was over on the other island, he knew better than to mess with us. Sure could have used my winch last summer to help me reel in this bad boy!
                        1982 Mercedes 300TD
                        1989 RRC
                        1993 D110
                        1994 RRC LWB
                        1995 RRC LWB
                        1995 RRC LWB
                        1995 Disco
                        1996 Disco
                        1997 Disco
                        2001 RR P38
                        2005 LR3 HSE
                        2006 RR HSE
                        • 1971Series88
                          • Dec 2011
                          • 172
                          #27
                          ^^^That^^^ is pretty funny - BUT very sad...
                          1963 Series IIa 109" 5 door Safari top (SOLD to new home)
                          1971 Series IIa 88" Soft top (SOLD to new home)
                          1995 RRC - LWB
                          2001 Discovery II SE7 (SOLD to new home)
                          • masonater
                            • Nov 2007
                            • 329
                            #28
                            sad indeed, i just couldn't resist. it was dead for weeks before it washed up. No word yet on the cause. Not too many of these left in the entire ocean, something like under 3,000 i think...
                            1982 Mercedes 300TD
                            1989 RRC
                            1993 D110
                            1994 RRC LWB
                            1995 RRC LWB
                            1995 RRC LWB
                            1995 Disco
                            1996 Disco
                            1997 Disco
                            2001 RR P38
                            2005 LR3 HSE
                            2006 RR HSE
                            • I Leak Oil
                              • 1796
                              #29
                              I think I can smell that from here!
                              What test were you using?
                              • yorker
                                • 1635
                                #30
                                I think tht is pretty cool. They have to die of something sometime, It is neat that you got to see it close up.
