OK so first post of probably many. Just recently got a 79 Santana off ebay. It is getting delivered tomorrow. Anyway, per the owner the Diesel Injector pump is weak and needs work. Apparently this is causing the engin not to run at full power. Any thoughts on this? As I understand it, injector pumps are usually fairly solid even at this age so could it be something else common to these 2.25 diesel engines?
If it is the pump, what is involved in replacing them? I've found a couple possible sources for replacement pumps but I've read some things regarding timing and so on. Anoy sort of specialized tools needed? I'm a noob regarding diesel (part of the reason I wanted to get one) so this is all a learning experience for me.
