Just got a 79 Santana...weak injector pump?
  • albersj51
    • May 2010
    • 687
    #16
    I dont know if it will work on a diesel pick up tube, but its worth a look
    http://siteground237.com/~gunsandr/s...k-pick-up-tube!!
    • yorker
      • 1635
      #17
      Yeah you can just add a sock- buy a modern one and modify it to fit. The old brass ones were soldered on IIRC but you should be able to get a modern one (Saran?) and make it work.
      Land Rover UK Forums
      • AirmanPika
        • Mar 2012
        • 29
        #18
        AHAHAHAHA ITS ALIVE!
        It kept stumbling at first like before but it seemed to keep trying harder and harder and finally it just started up. Had to purge a massive amount of air from the injector pump but it seems that was ultimately the only thing wrong. Now I'll need to give it a good workout to see how it does outside of the parking lot and go from there.
        • AirmanPika
          • Mar 2012
          • 29
          #19
          OK so in general the rover runs now, but I have to crank it forever to get it to go if I let it sit longer than a few minutes. I located a small leak coming from one of the metal lines going into the sedimentor. It is coming from the left line, middle of the U on the very bottom. Its so small that it just slowly seeps so my guess is its just rusted through. I can't find this part on the rovers north site though so either I'm not looking right or its not there. I could just hack it at a point before the leak, but I'd feel better with a new line.
          • Lalo88DK
            • Nov 2009
            • 116
            #20
            If you cant make or buy another, then cut off the rusty bit until you can fit a new fuel line to the remaining pipe piece.
