Exhaust down pipe
  • artpeck
    • Dec 2009
    • 368
    Exhaust down pipe
    I noticed exhaust coming out of the engine bay. Not a good sign but turned out a gap between the downpipe and the manifold. Is there a gasket that goes there or is it just a mechanical connection? s3. Thanks.
  • jonnyc
    • Dec 2011
    • 176
    Nope, no gasket there for a Ser.III 2.25 gas.
    • I Leak Oil
      • 1796
      Just a ball and socket joint. Try tightening up the 3 nuts. Spray it down with you're favorite rust buster (liquid wrench, kroil, etc.) and go easy. These like to break off just before you're big trip! Atleast that's when mine usually break.
      • rrc.swb
        • Jun 2011
        • 34
        I had the same issue. No gasket, just a ball joint on the down pipe and the socket on the manifold.
        Two of the studs lost their thread when I tighten them.
        Took the manifold to the shop and had them tapped with DII studs with brass nuts.
        1968 Poppy Red Series IIA 88" - Mr
        1964 Marine Blue Series IIA 109" - Mr Part II
        2003 Beluga Black DII - Mrs
        1996 Alpine White Disco I - Gone
        1996 Beluga Black 4.6L DI - Gone
        1992 Eastnor Green RRC SWB - Gone
        1991 Eastnor Green RRC Hunter - Gone
        1988
        Black RRC SWB - Gone
        • artpeck
          • Dec 2009
          • 368
          Thanks. I tried to tighten and snapped one off. The easiest fix looked to be to drill it out and use a nut and bolt. Is there an obvious or otherwise reason why that would not work? I love working on this truck but just when you think you have things buttoned up, there is always something else. Both the joy and the misery.
          • cedryck
            • Sep 2010
            • 836
            loooosy nuuutsy
            I have to tighten the 3 bolts at the connection of manifold and pipe after every other use of my Rover, darn vibration alway loosens the one closest to the engine block.
            • mongoswede
              • May 2010
              • 757
              are you using lock washers under the nuts?
              • jonnyc
                • Dec 2011
                • 176
                Or double-nut them.
                • Whiterabbit
                  • Feb 2012
                  • 66
                  If you drill them out for bolts you will have to grind the side of the bolt head or it wont sit flat.
                  If you have some copper flashing you can cut out a gasket for the joint and it'll conform to make a very good seal. Used to do the same thing with beer cans.
                  1978 MOD 109
                  • RNZack
                    Administrator
                    • Sep 2011
                    • 426
                    Although gaskets were not the genuine decision, they can definitely be helpful in sealing unwanted leaks.
                    • o2batsea
                      • 1199
                      Studs are usually the choice for manufacturers as it makes it easier for assembly line workers to assemble parts, not because they are superior fasteners.
                      I would sy go on and drill the thing for bolts/nuts.
