I noticed exhaust coming out of the engine bay. Not a good sign but turned out a gap between the downpipe and the manifold. Is there a gasket that goes there or is it just a mechanical connection? s3. Thanks.
Exhaust down pipe
Just a ball and socket joint. Try tightening up the 3 nuts. Spray it down with you're favorite rust buster (liquid wrench, kroil, etc.) and go easy. These like to break off just before you're big trip! Atleast that's when mine usually break.
I had the same issue. No gasket, just a ball joint on the down pipe and the socket on the manifold.
Two of the studs lost their thread when I tighten them.
Took the manifold to the shop and had them tapped with DII studs with brass nuts.1968 Poppy Red Series IIA 88" - Mr
1964 Marine Blue Series IIA 109" - Mr Part II
2003 Beluga Black DII - Mrs
1996 Alpine White Disco I - Gone
1996 Beluga Black 4.6L DI - Gone
1992 Eastnor Green RRC SWB - Gone
1991 Eastnor Green RRC Hunter - Gone
1988 Black RRC SWB - GoneComment
Thanks. I tried to tighten and snapped one off. The easiest fix looked to be to drill it out and use a nut and bolt. Is there an obvious or otherwise reason why that would not work? I love working on this truck but just when you think you have things buttoned up, there is always something else. Both the joy and the misery.1995 NAS D-90 Soft Top, AA Yellow
1957 Series I, Deep bronze greenComment
If you drill them out for bolts you will have to grind the side of the bolt head or it wont sit flat.
If you have some copper flashing you can cut out a gasket for the joint and it'll conform to make a very good seal. Used to do the same thing with beer cans.
1978 MOD 109Comment
Although gaskets were not the genuine decision, they can definitely be helpful in sealing unwanted leaks.Comment
