Thanks for your help everybody. As you may know I'm traveling around the western US in my truck right now sampling rocks for my research.
In a fit of utter desperation I dumped literally an eighth of a can of carb cleaner on the number 3-4 intake manifold. I just couldn't believe that the symptoms weren't caused by a vacuum leak. Well this time the engine nearly stalled and I nearly cried. I guess the liberal sprays that I used in the past were insufficient. Amazing because 3 people, including me, sprayed various products around the engine looking for a vacuum leak and decided there wasn't one. I suspect that the leak is on the lower side of the Manifold and unless you really soaked the manifold the fluid vaporized before reaching the leak and affecting the idle. I literally soaked the manifold in liquid.
So the good thing is I found a vacuum leak. The bad thing is I don't have a manifold gasket with me. Can one be cut from some material, much as you would do with any other gasket? I would imagine it needs to be a high temperature material due to the exhaust.
Thanks again for your help.
