Here is where I'm at with my original problem. Still won't start or even hit once. The starter turning the engine well (battery still holding up after a 1,000 cranks). The open points with the ignition on has 12 volts from hot side to frame and across the open points. However, I still can't see a spark when I pull a plug wire off and hold it over a frame bolt. I still see fuel being pumped and smell gas after trying to start it.
So, were do I go from here and what is the first part to replace? I have new plugs and they are gaped correctly. The pug wires are about 8 years old but look good and no arcing. A new coil? A new condenser? Why would something like this go out just with prolonged sitting? Thanks in advanced.
