Is this wise?
  • nate6472
    • Apr 2009
    • 133
    Is this wise?
    I have a primary and secondary battery, connected by a manual transfer switch. They are connected except when the rover is off. The secondary powers lighting and keeps the primary from loosing power for starting. Can using two batteries when starting and running damage anything? Thanks in advance
    sigpic
    Nate B
    88 D90 RHD, V8 Present
    80 Merc 230GE Petrol in 2011
    92 Range Rover - In the 90's
    cuis2000@yahoo.com
  • 4flattires
    • Aug 2007
    • 424
    This is a common practice in high amp draw starting situations...typically diesels. I'm guessing you (or someone) set this up to handle a situation, you might share that.
    Damage? No, not in a parallel setup. It's no different than in a jump start situation.
    But if there is no increased electrical reserve required by your truck, I would much rather carry 60lbs of tools, fuel, or a frosty beverage-based payload than one of a lead/acid composition. Just my 2c.
    64 SIIa 109 all stock
    69 SIIa 88 all stock
    Old tractors
    New Harleys
    Old trucks
    • nate6472
      • Apr 2009
      • 133
      I set this set up to run extra electrical devices while overnighting without taxing the primary battery. I guess I could only carry secondary when overnighting, saving weight.
      sigpic
      Nate B
      cuis2000@yahoo.com
      • 4flattires
        • Aug 2007
        • 424
        Ahhh, different story. So this second battery is a deep cycle then? Low draw amp, long draw time span. Much different than a typical starting battery, high draw amp, low draw time span. If this is the case, your manual switch is fine, you know when to disconnect it. Otherwise there are automatic battery isolator products out there that protect the starting battery from draining once the accessory battery has (or is) beginning to expire.
        Search battery isolators. You'll typically find this in RV situations.
        Old tractors
        New Harleys
        Old trucks
          I've looked for it but can't find the online page of do's and don'ts of dual battery setups. It was on one of the isolator/battery management system manufacturer's sites, IIRC. I thought it was Hellroaring.com but I can't find it there. I think I read that mixing 'normal' and deep cycle batteries in a dual battery setup was a no-no, but I can't find the reference on that. I'll keep looking...
          • nate6472
            • Apr 2009
            • 133
            Both of these batteries are off the self "starting" batteries
            sigpic
            Nate B
            cuis2000@yahoo.com
            • Donnie
              • 287
              Perko makes the switch that you are looking for.. U can choose 1 / 2 or both batteries & also comes with a lock & key position, Donnie
