My '75 SIII 109 came to me with a Ford diesel in it from a '71 Ford Transit that runs really well, gets relatively good mileage, can run on bio-diesel blends if I want to, and is fed by a fairly common minimec injection pump. I don't foresee any real problems in the near future with the engine--it's just a simple as they come.
But while many folks swapped out the 2.25 petrol engines in their 88's for Ford Transit diesels and found them up to the task, this engine doesn't quite give me the umph I'm looking for in my 109. I had a Fairey OD installed that made a big difference in my ability to maintain speed going up steep hills and the like, but at the end of the day, while the engine is fine off-road and in town at speeds of 60mph and below, I just would like a little more get up and go.
So, I'm thinking about swapping in a 200TDI and R380 gearbox like the one's available in this listing on ebay - http://www.ebay.com/itm/390358278661...84.m1438.l2649
Any red flags with this idea or things I should look out for? What should my expectations be as far as performance gains? Will I have to change the gear ratios in the front or rear diffs (front is a rover type, rear is a salisbury, no idea what the current ratios are or if lockers are installed)?
And what do you think a transit diesel w/ 4-speed & Fairey OD is worth these days to someone looking to do a diesel swap for their 88? The faiery OD cost me $800 alone, so maybe I should take it off and sell it separately?
