Okay, I trouble-shot and fixed my fuel gauge, but the fix was the strangest thing and I will describe.
So, I took out the sending unit and wired it directly to the gauge. As I played around with it, I noticed an odd thing . . . it was working in reverse. When the float was in the full position, the gauge read E and vice versa. Could they have sent me a positive ground (it is a brand new sending unit)? That didn't make sense plus I did reverse the polarity on the gauge and it still ran in reverse.
So I opened the metal box on the sending unit. I studied the mechanical and electrical components. Yes, as someone said, they are fragile. But then I noticed one glaring problem. From the factory the (what I would call the rheostat) was hooked up in reverse. When the float was in the full position, the lead would slide down to the most distant end of the rheostat and when the float was in the empty position, the lead was at the hottest end, next to the ground wire.
So, I did some micro surgery and reversed the rheostat. It was very difficult as the wires on it are apparently steel and as fine as a Hare's hair, and because they are steel, I couldn't solder them. But I cut one end and then created a connection from the opposite end to the ground. I put it back together. Guess what. It works perfectly now.
So what's up with that?
