Gas Gauge Not Working
  • mjones1700
    • Jul 2012
    • 40
    #16
    Okay, I trouble-shot and fixed my fuel gauge, but the fix was the strangest thing and I will describe.
    So, I took out the sending unit and wired it directly to the gauge. As I played around with it, I noticed an odd thing . . . it was working in reverse. When the float was in the full position, the gauge read E and vice versa. Could they have sent me a positive ground (it is a brand new sending unit)? That didn't make sense plus I did reverse the polarity on the gauge and it still ran in reverse.
    So I opened the metal box on the sending unit. I studied the mechanical and electrical components. Yes, as someone said, they are fragile. But then I noticed one glaring problem. From the factory the (what I would call the rheostat) was hooked up in reverse. When the float was in the full position, the lead would slide down to the most distant end of the rheostat and when the float was in the empty position, the lead was at the hottest end, next to the ground wire.
    So, I did some micro surgery and reversed the rheostat. It was very difficult as the wires on it are apparently steel and as fine as a Hare's hair, and because they are steel, I couldn't solder them. But I cut one end and then created a connection from the opposite end to the ground. I put it back together. Guess what. It works perfectly now.
    So what's up with that?
    • Partsman
      • May 2011
      • 329
      #17
      When I got mine, it was doing this too, I took a mildly easier route to fix it, I painted the gauge so it read right:
      Series 2 Club Forum
      Andy The Landy Shop
      • mjones1700
        • Jul 2012
        • 40
        #18
        Are your serious. LOL. That approach never crossed my mind . . . but would work.
        • Partsman
          • May 2011
          • 329
          #19
          It does quite well, but the approach you took, I have to give you props for, it never even crossed my mind to try and rewire the guts of the gauge, I didn't know it could be done that way.
          Series 2 Club Forum
          Andy The Landy Shop
          • sleam
            • May 2010
            • 104
            #20
            that's hilarious! I'd get stuck all the time though. It's bad enough remembering to look at the thing, not that it works right now. I'm going to check the ground wire first. And then reread this forum!
            1959 SII sold
            1972 SIII RHD 88" (current project!)
            • emmotto
              • Sep 2012
              • 87
              #21
              my gauge read always full and checking the ground didn't help - turned out to be bad voltage stabilizer - it would cycle continuously from 10v to 13v - about once a second. I bought a replacement solid state stabilizer and that solved the problem.
              Mike
              Mike
              1969 Series IIa 88 2.25 petrol
              • sleam
                • May 2010
                • 104
                #22
                thanks, I'l look into that too.
                1959 SII sold
                • rickv100
                  • Aug 2010
                  • 143
                  #23
                  I have the same issue on the my S3 109. Issue is with the fuse block, for some reason the fuse clamps are not working correctly. If I turn the fuse in the holder it works. I have tried swapping around fuses and taking fine sandpaper to the fuse jaws and it is still acting up.
                  Now I just live with it.
                  Rick
                  73 xMOD S3 109
                  52 M37
                  • sleam
                    • May 2010
                    • 104
                    #24
                    Thanks, I just checked the fuse box, cleaned it all up, made sure everything was tight, then did the same to the connection at the sender under my drivers seat (RHD). It works now!
                    1959 SII sold
