Admit up front I don't know enough about my problem so i'll do my best to explain but may ask many basic question.
Own a 67 88" with a 2.5 NA and trying to get everything working and ready to tackle the oil/water temp guage. Currently to the left of main guages in its own panel is a oil/water temp guage with oil on top and water below. Oil works ok but water temp has never worked. Currently water is hooked up through line to the top drivers side of the block in a fitting that just dips into coolent flow. I tried ordering factory 2.5 NA temp guage from UK and got what I assume is an electrical guage whereas I think what I have now is mechanical. Like to keep a factory land rover guage but if I have to i'll go aftermarket.
-Is the un-lit water/oil guage factory series?
-should it light up like my others?
-Is the original series guage mehanical?
-Is the original guage for the 2.5NA electrical?
-Is the stock 2.5 NA oil/water a combined guage that I can swap in?
I'm just sick of not knowing hows shes running and specialy after a new radiator install I really need to know
Thanks!
Josh
Thanks!
Josh
