Gauge panel question
  • o2batsea
    • 1199
    #16
    Originally posted by Revtor
    Definitely could be the problem. i bet you could get a 12v LED equiv.
    Fixed it for ya.
    • Jim-ME
      • 1379
      #17
      The work lamps were standard for the military and were offered as an option to civilians. I was very lucky to have been given one by a fellow Rover enthusiast as I had no idea that they even existed. I have purchased and resold several of these over the years but have always kept the one I was given. I have found mine very useful on several occasions. The really nice thing is that they are small thus easy to store and you don't have to worry about batteries corroding like a flashlight. The cord is long enough to be able to go front to rear on a 109. The work lamps are supposed to have the same bulb as a running light. It is possible that the wrong bulb is installed in the work light which is what is causing it to heat up. I have not thought about switching to a LED but that isn't a bad idea.
      • TedW
        • 887
        #18
        Jim is right about how useful and practical these lights are. Like many pieces of equipment that have military origins, they are (in a good way) way overbuilt: you can bash them around and they will keep working.
        • Dietersrover
          • Aug 2011
          • 76
          #19
          use a Series Back up light
          Our host sells Series and Defender back up (reverse lights). These would be easy to hook up as a dome or work light.
          • Dietersrover
            • Aug 2011
            • 76
            #20
            I remembered this post this morning, and took a couple of images of my plug for you.
ID:	167715Click image for larger version
            • NDNAJNS
              • Jan 2012
              • 42
              #21
              [ATTACH=CONFIG]7848[/ATTACH][ATTACH=CONFIG]7849[/ATTACH]
              Thanks! Is that the one from our hosts?
              1965 88 Petrol
              2009 MB C300
              • east high
                • Jan 2008
                • 337
                #22
                I got mine here: http://www.triple-c.com/Products_and...CAB185&pID=855
                '67 sIIa 88
                • Dietersrover
                  • Aug 2011
                  • 76
                  #23
                  No, only because I got mine with my Series and its from the UK.
                  Same item though.Check Radio Shack also.
