RangeRover wheels on a Series??
  • timc930
    • Jul 2013
    • 117
    These look like the steel spare wheel that came with the RRC's, anyone used them on a series? I have a few of these from previous RRC's that I may try, but wanted some feedback first....
    Tim
    63 IIA 88" (Beach with the dogs)
    05 L322 (Daily)
    95 RRC SWB
    05 E320 (Wife)
    86 930 (Rush on boost, 400HP and climbing....)
    A few boring BMW's for the kids (E30, E36, E46, E53)
  • I Leak Oil
    • 1796
    Steel wheels should fit. Easy enough to slap on on to make sure.
    • o2batsea
      • 1199
      RRCs never had steel wheels to my knowledge (except for the early Rostyles). They all came with alloy spares, at least the NADA ones.
      Those appear to be Disco 1 spare tire wheels. This was a popular switch in the 1990s, for some unknown reason.
      • timc930
        • Jul 2013
        • 117
        Those appear to be Disco 1 wheels. This was a popular switch in the 1990s, for some unknown reason.
        I have two 95 Classic's, and both came with steel spares.
        Tim
        05 L322 (Daily)
        95 RRC SWB
        05 E320 (Wife)
        • ArlowCT
          • Jul 2008
          • 238
          Those look like the rims I'm about to have cut down and fit on my 88"!
          • o2batsea
            • 1199
            Are they County models or regular? Curious to know if the steel spare was on the low line trucks.
            • timc930
              • Jul 2013
              • 117
              Both of mine were County's fully loaded, that had the TWR Designed LR wheels that became standard on the 95's, and some Defenders.
              Tim
              05 L322 (Daily)
              95 RRC SWB
              05 E320 (Wife)
              • timc930
                • Jul 2013
                • 117
                Why do they need to be cut down, and by cut down what do you mean, width?
                Tim
                05 L322 (Daily)
                95 RRC SWB
                05 E320 (Wife)
                • mearstrae
                  • Oct 2011
                  • 592
                  I have the same wheel as a spare with my County Lwb. Once used it as a spare on my SIII.
                  '95 R.R.C. Lwb
                  '76 Series III Hybrid 109
                  '70 Rover 3500S
                  • ArlowCT
                    • Jul 2008
                    • 238
                    I'm taking 1" out of the width. I think they should work real well at that size with the narrow tires on them. The rims were cheap and my labor is free so we will see how it turns out!
                    • Andrew IIA
                      • Feb 2008
                      • 327
                      How wide are those wheels ?
                      Andrew
                      '63 SIIA 88" SW
                      • Apis Mellifera
                        • 386
                        Seems like they are 7s. They might be 8s. I have one I was going to use as a bonnet spare. It was so tall I felt like I was peering out the gunner's slot of a tank.
                        • ArlowCT
                          • Jul 2008
                          • 238
                          The ones I have are 7" right now, soon they should be 6"!
                          • tuko
                            • 22
                            [ATTACH=CONFIG]8518[/ATTACH]
                            Those are not RRC wheels. They are Disco I steels that were introduced in 1989/90 with the Disco I. The steel in these wheels are the same thickness as Wolf rims making them great HD alternative wheels for series vehicles. The downside with the extra thickness is that the wheel studs are a bit short which does create a safety concern. If you regularly check your wheel nuts then no problem, but there has been a few accidents in England where the wheels have come off from lack of maintenance. I'd have to check the set in the garage but I'm sure that they are 7" wide.
                            Todd.
                            My Series 3 Hybrid
                            300Di Powered
                            Småland Traxx - Offroad Aventure Tours. More info can be found on Facebook.
                            • antichrist
                              • Mar 2009
                              • 272
                              RRCs never had steel wheels to my knowledge (except for the early Rostyles).This was a popular switch in the 1990s, for some unknown reason.
                              I expect it was to fit wider tires and still keep within tire mfg specs.
                              Also I was told by someone who worked at a POE that the Discos were actually shipped over with steel wheels then switched to alloys, so the steel ones were cheaper to find than old Series wheels in good shape. I have no idea if that's true or just something the person was mixed up about.
                              Tom Rowe
                              62 88 reg
                              67 NADA x2
                              95 D1 - R380
                              95 D90 - R380
                              97 D1 - ZF
