Greetings all! In my ongoing attempts to make the world (or at least the part of the world in front of my Series III 88") a brighter place, I have procured a set of used Hella 4000FF Eurobeams with 100W bulbs. These are the Free Form lamps rather than the standard lamps with the patterned lenses. The FF lamps are not my first choice, but the price was right...
Anyway, I plan to mount these to my front bumper but am looking for input on the spacing of the lamps. Here are my options:
Narrow spaced:
and wide spaced:
Do others with more experience have any pros or cons to the two mounting options? These are driving lights and have the Hella Eurobeam pattern.
The narrow spacing uses an existing set of pilot holes in the bumper, it that makes any difference at all.
Also FYI, my headlights are IPF E code conversion units running 100W/130W Narva H4 bulbs. I have a SMS headlight wiring harness (with relays) and have converted to a GM alternator.
The Hellas will be mounted using the Hella wiring harness with fused relay.
Thanks in advance!!
Narrow spaced:
and wide spaced:
Thanks in advance!!
