Wanted air cleaner land rover series 2
  • Belkcoyote
    • Aug 2013
    • 32
    I am looking for a used air/oil cleaner for my land rover series2 year 1962. I will need also the elbow hose to connect to the carburetor. Thank you.
    Pat
  • Cutter
    • Feb 2009
    • 455
    Are these different than a series III? If not I have one of each but I'm not keen on shipping. I'm in RI
    • scatterling
      • 183
      PM sent
      Neil Hanekom
      '73 LHD 88
      '99 D1
      • siiirhd88
        • 383
        Note that there are at least two different diameters at the carb end of the elbow, and several variations of the elbow small hose tubes.
        Bob Click image for larger version
Name:	Both carb tubes.jpg
ID:	168353 Click image for larger version
Name:	Large carb tubes.jpg
ID:	168354 Click image for larger version
Name:	small carb tubes.jpg
        • Belkcoyote
          • Aug 2013
          • 32
          Thank you Bob. I did not know that. I need the small diameter one. My elbow should be the simple one.
          Kindly.
          Pat
          • leafsprung
            • 1008
            62 would have come with a solex carb and have a larger opening on the elbow.
            Kindly.
            Pat
            • siiirhd88
              • 383
              The smaller elbow is 2.25" in diameter, the larger is 2.5". There is a rubber tube that connects the carb to the elbow. I know the Weber carb has a metal adapter that slips over the small diameter carb opening in order to fit the large diameter rubber tube and elbow.
              • Belkcoyote
                • Aug 2013
                • 32
                Rochester B1 carburetor
                [QUOTE=siiirhd88;98299]The smaller elbow is 2.25" in diameter, the larger is 2.5". There is a rubber tube that connects the carb to the elbow. I know the Weber carb has a metal adapter that slips over the small diameter carb opening in order to fit the large diameter rubber tube and elbow.
                Hello,
                I just figure out my carburetor is a Rochester B1 which Is not original for my 1962 land rover series 2. The diameter is 2.25. Is it a good brand or I should buy a solex one. Thank you for your help.
                kindly
                Pat
                • siiirhd88
                  • 383
                  The B type Rochester is a simple and fine carb, if not the most fuel efficient, for your truck. If set up right, it is considered an 'upgrade' carb, and rebuild kits are available at many auto parts stores.
                  I have a Rochester on my 109 and due to its height the elbow was rubbing on the underside of the bonnet. I trimmed a bit metal off of the carb end of the elbow, and shortened the rubber tube to gain some clearance.
                  • Belkcoyote
                    • Aug 2013
                    • 32
                    Thank you Bob!
                    [QUOTE=siiirhd88;98301]The B type Rochester is a simple and fine carb, if not the most fuel efficient, for your truck. If set up right, it is considered an 'upgrade' carb, and rebuild kits are available at many auto parts stores.
                    I think I am going to keep it. It is going to work better with an air filter. Now it's not responding right away. Too much air.
                    Do you have a de luxe bonnet? Or the flat one.
                    thank you
                    Pat
                    • siiirhd88
                      • 383
                      This 109 has a dished "de luxe" bonnet. I don't think your problem is too much air. Slow response is likely worn seals on the accellerator pump piston (could be leather) or the accellerator pump linkage not set right.
                      [QUOTE I think I am going to keep it. It is going to work better with an air filter. Now it's not responding right away. Too much air.
                      thank you
                      Pat[/QUOTE]
