Series III Battery Issues?
  • canyonero
    • Aug 2011
    • 52
    Hello all,
    Given the 0-20F weather we have had endured for the past few months, (during which my Series has rarely started) should I take a battery voltage reading of 10.75 as a sign of a dead battery in need of replacement? Few lights come on when the key is turned, and the battery has is of indeterminate age, it was in the truck when I got it three years ago.
    Thank you.
    1973 Series III, 109, Ex-Mod
    1999 Discovery II, Cataclysmically Lost
    • NC_Mule
      • Mar 2010
      • 222
      Another member posted this for me last month when it was -11 and I had 12ish volts and a no start condition. Below freezing and 12ish volts is a dead battery, at any temp 10.75 is a dead battery. At the sub freezing temps our basic generator charging system can't keep up. I even found a tip printed in the green bible to plug your truck into a trickle charger if under continuous freezing conditions. I'm at the end of a alternator conversion followed by a dual battery set up so I don't have trouble in cold weather again.
      pb
      edit: haha pretty sure SafeAirOne was the member who gave me this handy chart.
      • canyonero
        • Aug 2011
        • 52
        Ahhh yes, new battery it is.
        Thanks all.
        Originally posted by NC_Mule
        [ATTACH=CONFIG]9473[/ATTACH]
        pb
        • NC_Mule
          • Mar 2010
          • 222
          Once you get a new battery make sure your charging system is up to spec or you will have another dead battery down the road.
            Yeah, that's the one I was searching for, but only found the other one I linked to.
