after a routine Friday spin found this , the hole where it seems to be coming from looks threaded but not clean like a bolt just came out any thanks gareth dallas tx
oil leak
Zimbo,
Well, they all leak, but this looks a bit more than usual. Rear main seal is my best guess. Oil looks a bit black, may be time for a change. As for the threaded hole, I think it's supposed to be open unless fording rivers and such.
Rob
68 series 2a Bug Eye -
is this rear main a nightmare , do I have to take off driveshaft, tunnel covers etc I assume the gearbox needs to be dropped and clear of working area
any idea why it would leak all of a sudden like that , the only thing ive changed recently is the air filter bypassed the oil bath for a whileComment
Is the crankcase being sufficiently vented? If the vent has been eliminated or obstructed, the pressure could build up, blowing stuff past the seals.--Mark
I don't have a 2.25 engine, but venting usually takes the form of a vented oil fill cap or a PCV system.--Mark
I checked the venting all seems good , I did a oil change also dropped the pan cleaned out the sludge ,new gasket installed new oil and filter , drove around town and leak seems to still be there , rear main job in the pipeline . any ideas on shop rates for this I will have a shop do this too big for meComment
I had a shop do mine last year. Small local garage, that I went to high school with the owner. I think it set me back around $900. I did pick up the parts, including a fresh clutch, I removed the wings radiator and breakfast so I could save myself some shop labor.Bad gas mileage gets you to some of the greatest places on earth.Comment
This isn't a terrible job to do yourself - it's just no fun. In a nutshell... take the seat box/floor/tunnel out, disconnect the rear prop, and you should be able to pull the transmission out. I think I had my tub off at the time, but I don't think that was necessary. After that, you can get to the rear seal by removing the drain pan. The seal (~ $15) is sort of an interesting split design. Replace the clutch before you bolt the transmission back on.
I can't say doing it made me a better person, but it really wasn't that bad.1967 IIA 109 Regular RHD
1993 Range Rover LWB (gone, thankfully)
1969 IIA 88 Bugeye (gone, unfortunately)Comment
